BAM Flight Cover for Manouche Case BAM Flight Cover for Manouche Case BAM Provides extra protection when flying with your BAM case. Arts & Entertainment bam-manouche-flightcover 8005H 4.0 1
4 5
This cover is designed to fit very snugly over the BAM Manouche case. I found it to be a bit tight at first, but it will probably loosen as it molds to the BAM case. The padding is very thick and should prevent any damage during traveling.
458.00 DjangoBooks.com
Home / Guitars / Guitar Cases / BAM Flight Cover for Manouche Case
Ideal for air cargo transportation.
Weight
 : 4 kg
Inside dimensions : 107x47x18 cm
Outside dimensions : 115x52x21 cm
Inside Features :
  • Extrathick layer of high density polyurethane foam
  • Dedicated mold taking on the exact shape of the guitar case and protecting it against shocks
Outside Features :
  • Zipper
  • Flat front pocket
  • 2 retractable padded backpack straps
  • Side handles
Color : Black
$539.00 $458.00 (Save 15%)
Pros: Great padding and design
Submitted by: Neil on 11/06/2017 07:11:14 PM
BAM Manouche Carbon Fiber Gypsy Case
Deluxe French made ABS case for Gypsy jazz guitars!
$1,163.00 $989.00 (Save 15%)
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.02126 Seconds Memory Usage: 2.101891 Megabytes
