Home / Amplification / Pickups / Audio-Technica PRO 35 Cardioid Condenser Clip-on Instrument Microphone
Designed for sax, toms, brass and percussion, the PRO 35 excels in high-SPL applications and is ideal for active stage performances. The Pro 35's extended frequency response captures all the subtle nuances of the performance. The included UniMount clip permits accurate positioning and provides shock resistance while protecting the element. The microphone's cardioid polar pattern reduces pickup of sounds from the sides and rear, improving isolation of the desired sound source. Any time you need high-quality capture on-stage, the Audio-Technica PRO 35 is there for you!
Audio-Technica PRO 35 Features:
  • UniMount clip permits accurate positioning, provides shock resistance and protects element
  • Cardioid polar pattern reduces pickup of sounds from the sides and rear, improving isolation of desired sound source
  • Extended frequency response captures subtle nuances of the performance
  • 6' (1.8 m) cable permanently attached between microphone and power module
  • Element: Fixed-charge back plate, permanently polarized condenser
  • Polar Pattern: Cardioid
  • Frequency Response: 50HZ-15kHz
  • Low Frequency Roll-Off: 80Hz, 18 dB/octave
  • Open Circuit Sensitivity: -45 dB (5.6 mV) re 1V at 1 Pa
  • Impedance: 250 ohms
  • Maximum Input Sound Level: 145 dB SPL
  • Phantom Power Requirements: 11-52V DC, 2 mA typical
  • Switch: Flat, roll-off
  • Output Connector (Power Module): Integral 3-pin XLRM-type
  • Cable: 6.0' long (permanently attached to microphone), 0.10" (2.6 mm) diameter, 2-conductor, shielded cable
  • Furnished Accessories: AT8418 UniMount microphone instrument mount; AT8538 power module; soft protective pouch
  • Case
$199.00 $159.00 (Save 20%)
Audio-Technica AT8418 Unimount Microphone Instrument Mount
$49.99
Audio-Technica AT8468 Guitar or Violin Mount
The Audio-Technica AT8468 is a hook-and-loop fabric, touch-fastener mount for mounting lavalier microphones to violin and guitars.
$21.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.016671 / 1.532295]
