Home / Amplification / Amplifiers / AER Domino 2A Acoustic Amplifier
An entire mini P.A. system hidden inside a guitar amp, the Domino consists of four channels (2 x guitar, 2 x voice) and 2 x 60W power amps. A built in reverb / delay unit offers a choice of 4 preset sounds; alternatively, the effects loop enables the amp to be connected up to an external effects unit.
Other features include stereo outputs with a stereo widening option to connect up to a larger P.A. system, and 24 Volt Phantom power to allow the use of condenser microphones on the voice channels.
Includes a soft cover.
$3,499.00 $2,699.00 (Save 23%)
Amp Specs
Inputs
channel 1 and 4 6.3 mm (1/4”) input jack socket as high impedance
line input stage with pad (high/low attenuation)
channel 2 and 3 combined XLR/6.3 mm (1/4”) input jack socket as
high-quality line- or balanced microphone input
stage 48 V phantom power, gain control.
Tone Controls
equalizer three band tone controls
colour ‘mid-cut-treble-boost’- filter
effect 32 bit AER digital effect processor with 16 presets,
individual effect sends per channel
Power
power amp 100 W / 4 ohms, dynamic control
analog signal subsonic filter, low distortion
processing RMS limiter
Speaker
2 x 8“ twin cone speaker system
Features
rec out, aux in, headphones, tuner, L/R out, insert, line
out, DI-out, send, return, footswitch (internal/external
effect on/off , mute channels)
Accessoiries
softcover
Specifications
cabinet 15 mm (0.59”) ! nnish birch plywood
finish waterbased acrylic, black spatter finish
dimensions 365 mm x 420 mm x 295 mm
(14.37“ x 16.53“ x 11.69“), HxWxD
weight 13,95 kg (30.76 lbs)
Can be combined with:
AS 281
AS Q8
Outlaw Amp Ramp
$26.95
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.023419 / 2.609749]
