AER Compact 80 pro
Compact 80 pro
We proudly present the new AER Compact 80 pro!
The demand for an even more flexible and more powerful version of AER's best-selling Compact 60 amp from the singer-songwriter community led us to design the Compact 80 pro.
Completely made in Germany with the famous reliability that AER is known for. This amp will inspire and accompany you for years to come.
More power for an even more dynamic sound, a slightly bigger cabinet to enhance the low end of your sound. This is what works great for singers and gives your instruments a fuller sound with the same AER punch and clarity. You can easily fill a room of 150 people with this. Still very small and lightweight, a gigbag is included.
A myriad of possibilities on the back. The most striking one is the Couple in with its volume control allowing you to accept the signal of another amp, so your Compact 80 pro functions as a monitor. Left and right outputs to send your signal to FOH speakers. Two very high quality DI Outputs with or without effects, a feature any sound engineer will applaud. A professional effect loop. Footswitch connections to mute the amp and/or mute the effects.
$2,999.00 $2,399.00 (Save 20%)
Specs
Channel 1: 6.3 mm (1/4”) jack socket as high-impedance line input with pad (high/low attenuation) and switchable 9 V phantom power, gain control
Channel 2: combined XLR/6.3 mm (1/4”) jack socket as high-impedance line or balanced microphone input, 48 V phantom power, gain control
Channel 3: 6.3 mm (1/4”) jack socket as high-impedance line input with pad (high/low attenuation) and switchable 9 V phantom power, gain control
Channel 4: combined XLR/6.3 mm (1/4”) jack socket as high-impedance line or balanced microphone input, 48-V-phantom power, gain control
Equalizer: three band tone controls for channel 1, 3 and two band tone controls for channel 2, 4
Colour: ‘mid-cut-treble-boost’-filter
Effects: two digital effect processors with 4 presets: 2 x reverb, delay, chorus
Power amp: 80 W / 8 ohms, Analog signal subsonic filter, low distortion processing RMS limiter
Speaker system: 2-way speaker system, 8” (200 mm) polypropylene low-midrange neodymium alloy magnets
Features: Couple-in, ground lift, switchable 9 V phantom power, adjustable aux in, footswitch (effects on/off ), tuner, line out, adjustable DI-out, parallel effect loop, headphones
Dimensions
Height: 320 mm (12.6”)
Width: 325 mm (12.8”)
Depth: 285 mm (11.22”)
Weight (without gigbag): 10 kg (22 lbs).
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.022943 / 1.962791]
