AER Cheeky D AER Cheeky D AER Electric guitar tube amp from AER! Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers aer-cheeky-d CHEEKY-D 5.0 2
5 5
Just got this amp and was glad to be able to get one right away. I had a compact 60 and knew the quality was there even though it is on the pricy side. The amp is living up to expectations, too much fun and I haven't even dialed it in yet. This thing kicks ass.
5 5
One wants to hesitate on putting 5 Stars on the Value of this amplifier, but, when one considers buying TWO amps to do what this amp alone does, the value becomes obvious. First of all, the AER amps are built with uncompromised quality. If one has played the acoustic models one will find that same sturdiness and clarity as in those models. Second, the POWER in this little amp works for ANY kind of live playing, of acoustic or electric guitar. Third, with this one amp one can quickly move from a ...
2099.00 DjangoBooks.com
Home / AER Electric Guitar Amps / AER Cheeky D
AER Cheeky D
AER Cheeky D
It has been a challenge for long and so here they are: The first AER amps for electric guitar.
Solid state input-stage and tube input-stage, tube distortion,
and 200 watt high efficiency solid state power-amp. According to AER‘s sound philosophy, the cheeky d. is extremly clear, powerful and direct. It offers the sensitivity and distinction to follow the smallest changes and provide you with enormous dynamic reserves. On the contrary the d. 12“v, with its more classic approach, stays warm and smooth and has an eye for the vintage-orientated players.
For jazz, fast as hell for country-rock and fat and loud for
rock ‘n‘ roll.
AER Cheeky D
6600 - AER Cheeky D
$2,399.00 $2,099.00 | Out Of Stock | Stock Notification
Amp Specs
• 200 watts, dynamic control
• 10“ (250 mm) twin cone fullrange speaker
• Single channel guitar combos
• 4 digital effect presets and distortion
• 16 kg (35.50 lbs)
Inputs
input 1 6.3 mm (1/4”) input jack socket for clean channel 1. Switchable to distorted channel 2, if input 2 is not used.
input 2 6.3 mm (1/4”) input jack socket for
distorted channel 2
Tone Controls
equalizer three band tone controls
colour ‘mid-cut-treble-boost’-filter
effect Built-in digital effect processor with 4 presets
(Reverb, Chorus, Delay).
Power
power amps 200 W / 8 ohms
dynamic control
analog signal subsonic filter, low distortion
processing RMS limiter
Speaker
10” (250 mm)
AlNiCo guitar loudspeaker
Closed cabinet (all models)
Features
headphones, line out, footswitches (distortion on/off, dark/bright and internal effect on/off), send, return, insert pre/post EQ, tuner, aux in, speaker sim, adjustable DI-out, ground lift
Accessoiries
padded gigbag, footswitch
Specifications
cabinet 15 mm (0.59”) finnish birch plywood
finish waterbased acrylic, black spatter finish
dimensions
325 x 376 x 296 mm
(12.80“ x 14.80“ x 11.70“) (HxWxD)
weight
16 kg (35.50 lbs)
cheeky d. 10
Submitted by: ralpheee on 10/03/2015 01:15:41 PM
Great all-around amp
Pros: Metal grill, "blackface" console, strong handle
Cons: No speaker-stand socket
One wants to hesitate on putting 5 Stars on the Value of this amplifier, but, when one considers buying TWO amps to do what this amp alone does, the value becomes obvious. First of all, the AER amps are built with uncompromised quality. If one has played the acoustic models one will find that same sturdiness and clarity as in those models. Second, the POWER in this little amp works for ANY kind of live playing, of acoustic or electric guitar. Third, with this one amp one can quickly move from a Selmer-type guitar to a Taylor ES to a Stratocaster or a standard jazz guitar with one or multiple pickups and be ready to play with a minimum of fuss, And in the studio, all the sound one can set up can be directed to a recording console or DAW through the direct-out jack or by microphone on the speaker. Quiet and powerful. I expect many years of service and fewer pieces to transport or set up.
Submitted by: Bob P. on 04/02/2011 07:45:28 AM
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013607 Seconds Memory Usage: 1.363762 Megabytes
