Home / Amplification / Amplifiers / ACUS Amplifiers / Acus One for Strings 8 Acoustic Guitar Amplifier (wood)
Acus Sound Engineering developed the One for Strings range to amplify the sound level of all acoustic instruments (notably acoustic and classical guitars) without altering their natural tone or resonance. One for Strings amps are designed in minimalist style, with custom speakers, cabinets and highly reliable electronic components, all together capable of amplifying harmonics with natural tone.
One for Strings 8 is the second largest in their line of acoustic amplifiers, featuring a 200W acoustic guitar amplifier and an 8" Woofer and compression tweeter. The amplifier is equipped with 3 inputs (2 Mic-Line and 1 Line) complete with PEAK LED, GAIN, 4-band equalizer, effect SEND and VOLUME. It includes additional connections as AUX input with dedicated Volume and two-band equalizer and manual "feedback canceler" filter. The headphone output with dedicated volume control and the four high quality digital effects integrate the multifaceted system equipment.
Item: 03000801
$1,299.00 | Out of Stock | Stock Notification
Specs
Frequency Response: 40Hz - 20kHz
Max Power Out: 200W RMS
System format: 2-way biamp.
Woofer Power: 150W RMS
Tweeter / Horn Power: 50W RMS
Sensitivity 1W 1m: 94dB
SPL MAX: 116dB
Crossover: Electronic
Woofer size: 8"
High Freq driver: Compression tweeter
Box: 2 way bass reflex
Construction: Plywood
Weight: 28.6 lbs
Dimensions: Height: 37.5cm
Width: 27.5cm
Depth: 31.5cm
Acus One for Strings 8 Bag
Fits the Acus One for Strings 8, One for All, and One for Strings Extension model amplifiers.
$119.99
Acus One for Strings Extension Cabinet (black)
The Acus One for String Extension cabinet is an extension sound box designed as a small PA system, particularly suitable to the sound of acoustic instruments.
$899.00
Acus One for Strings Extension Cabinet (wood)
$899.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.052923 / 5.487877]
