Acus One for Strings 5T Acoustic Guitar Amplifier (wood) Acus One for Strings 5T Acoustic Guitar Amplifier (wood) Acus The Acus One for Strings 5T Acoustic Guitar Amp is a 50-watt combo that comes fitted with a 5" woofer and a compression tweeter. Arts & Entertainment > Hobbies & Creative Arts > Musical Instrument & Orchestra Accessories > Musical Instrument Amplifiers Acus-One-for-Strings-5T-acoustic-amplifier-wood 03000503 5.0 1
5 5
Acus 5T is a fantastic amplifier. Lightweight, reliable, powerful, clean, well-balanced highs vs. lows. Simple straight forward design. Plenty of EQ. 3rd channel for I-pod. I have owned original Trace - Elliot TA-50 and TA-100, AER compact 60 and Domino, Schertler Unico (generations 1 & 2), David (2nd gen.), Jam 100, Jam 200, 150 ext. and of all these amplifiers only the Acus 5T and the Schertler 150 extensions seem to have no issues. Perfectly engineered.
799.99 DjangoBooks.com
Home / Amplification / Amplifiers / ACUS Amplifiers / Acus One for Strings 5T Acoustic Guitar Amplifier (wood)
Acus Sound Engineering developed the One for Strings range to amplify the sound level of all acoustic instruments (notably acoustic and classical guitars) without altering their natural tone or resonance.  One for Strings amps are designed in minimalist style, with custom speakers, cabinets and highly reliable electronic components, all together capable of amplifying harmonics with natural tone. One for Strings can also be used as a mini PA system. It is versatile and responsive, with a full range of functions specifically tailored for acoustic instruments.
Perfect for gigging, practice or recording, the Acus One for Strings 5T Acoustic Guitar Amp is a 50-watt combo that comes fitted with a 5" woofer and a compression tweeter. The dual channel design allows you to plug in your acoustic instrument and a microphone simultaneously. The One for Strings 5T is equipped with two separate inputs (one Mic-Line and one Line), with controls for Gain/Volume, 3-Band EQ, Effect Send and Master Volume. The dedicated AUX input (with its own volume) allows for connecting an mp3 player or iPod. The system also features an electronically balanced direct output, 40W woofer power, electronic crossover, 5-in. woofer size and 2-way bass reflex.
The compact and lightweight speaker cabinet is handmade in natural wood, emphasizing the minimalist design and look of Acus products. It is birch ply with a protective polyester top coat. Easy to carry, highly versatile, and uncompromising sound quality!
$1,068.00 $799.99 (Save 25%)
Specs
Frequency Response: 50Hz - 20kHz
Max Power Out: 50W RMS
System format: 2 way biamp.
Woofer Power: 40W RMS
Tweeter / Horn Power: 10W RMS
Sensitivity 1W 1m: 90dB
SPL MAX: 108dB
Crossover: Electronic
Woofer size: 5"
High Freq driver: Compression tweeter
Box: 2 way bass reflex
Construction: Plywood
Weight: 7kg
Dimensions:
Height: 30.5cm
Width: 25.5cm
Depth: 26.5cm
Acus 5T amp
Pros: Everything
Cons: None
Submitted by: Richard Stratton on 02/12/2022 05:34:05 PM
Acus One for Strings 5T Acoustic Guitar Amplifier (black)
Acus One for Strings 5T Bag
Fits the One for Strings 5 and One for Strings 5T model amplifiers.
$89.99
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.014686 Seconds Memory Usage: 1.429932 Megabytes
