Acus ONEFORSTREET 5 Acus ONEFORSTREET 5 Acus ONEFORSTREET 5 the lightest portable amplifier ever. Arts & Entertainment > Hobbies & Creative Arts > Musical Instrument & Orchestra Accessories > Musical Instrument Amplifiers Acus-One-for-Street-5-acoustic-amplifier-wood 03000503 799.99 DjangoBooks.com
Home / Amplification / Amplifiers / ACUS Amplifiers / Acus ONEFORSTREET 5
Acus ONEFORSTREET 5
Acus ONEFORSTREET 5
Thanks to the multimedia accessories (included) it is extremely versatile for your live performances.
The amplifier with two power systems:
- External mains power supply (included)
- Makita compatible quick connect battery 18V 3.0 ~ 6.0Ah (not included)
This makes your amp tireless throughout your day. Anywhere, Anytime.
ONEFORSTREET 5 is a 40 Watt acoustic and classical guitar amplifier equipped with 2 separate inputs (channel 1: Microphone or Instrument input, channel 2: Instrument input) plus an Aux input (which can be with 3.5mm stereo jack or with the Bluetooth Acus Artesia BT-1) equipped with independent volume.
The 2 inputs are equipped with Gain / Volume, 3-band EQ and effect send. The system is equipped with an internal effect (Reverb type) and Master Volume, balanced Direct Out output (equipped with an attenuation switch, indicated with "-10dB", to adapt the Direct Out level to a Microphone input) and battery charge indicator LED (active only when the system is powered by battery).
The microphone input is equipped with always active phantom power.
$799.99
Specs
Frequency response: 50 Hz -20kHz
Max Power out: 40W
Channels: 22
System format: 2 way amp
Woofer power: 30W
Tweeter Power: 10W
Sensivity 1w 1m: 85 dB
SPL Max: 100 dB
Crossover: Electronic
Woofer size: 5"
hF speaker: dome tweeter
Construction: Plywood
Height: 30,5 cm
Width: 25,3 cm.
Depth: 28 cm
Weight: 7 kg
Acus One for Strings 5T Acoustic Guitar Amplifier (black)
The Acus One for Strings 5T Acoustic Guitar Amp is a 50-watt combo that comes fitted with a 5" woofer and a compression tweeter.
$1,068.00 $799.99 (Save 25%)
Acus One for Strings 5T Bag
Fits the One for Strings 5 and One for Strings 5T model amplifiers.
$89.99
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.022198 Seconds Memory Usage: 2.344162 Megabytes
