Home / Amplification / Amplifiers / ACUS Amplifiers / Acus ONEFORSTREET 10
ONEFORSTREET 10 the lightest portable amplifier ever.
Thanks to the multimedia accessories (included) it is extremely versatile for your live performances.
The amplifier with two power systems:
- External mains power supply (included)
- Makita compatible quick connect battery 18V 3.0 ~ 6.0Ah (not included)
This makes your amp tireless throughout your day. Anywhere, Anytime.
ONEFORSTREET 10 is a 120 Watt small band amplifier equipped with 3 separate inputs (channels 1 and 2: Microphone or Instrument input, Channel 3: Instrument input) + an Aux input (which can be with 3.5mm stereo jack or with the Bluetooth Acus Artesia BT-1) equipped with independent volume. The 3 inputs are equipped with Gain, 3-band EQ, effect send and Volume.
Input 1 is also equipped with other functions: it has a Compressor and a switch that changes the characteristics of the channel according to the type of instrument selected:
1. Flat: "standard" equalization for acoustic and classical instruments. With this equalization channel 1 is identical to channels 2 and 3
2. Bass: suitable for instruments particularly rich in bass (such as electric, acoustic or double bass).
3. Jazz: suitable for electric or semi-acoustic / jazz guitar.
The system is equipped with Master Volume, balanced Direct Out output (equipped with an attenuation switch, indicated as "-10dB", to adapt the Direct Out level to a Microphone input), battery charge indicator LED (active only when the system is powered by battery) and an internal multi-effect (2 Reverbs, a Chorus and a Delay).
All effects have a potentiometer for adjusting the parameters of the selected effect, namely the length for the reverbs, the duration for the delay and the Rate for the Chorus. The microphone input is equipped with always active phantom power.
Item: 10
$1,399.00 | Out of Stock | Stock Notification
Specs
Frequency response: 40 Hz -20kHz
Max Power out: 120W
Channels: 3
System format: 2 way amp
Woofer power: 100W
Tweeter Power: 20W
Sensivity 1w 1m: 94 dB
SPL Max: 114 dB
Crossover: Electronic
Woofer size: 10"
hF speaker: compression driver
Construction: Plywood
Height: 42,5 cm
Width: 30,2 cm
Depth: 31 cm
Weight: 11 kg
Acus One for Strings 5T Acoustic Guitar Amplifier (black)
The Acus One for Strings 5T Acoustic Guitar Amp is a 50-watt combo that comes fitted with a 5" woofer and a compression tweeter.
$1,068.00 $799.99 (Save 25%)
Acus One for Strings 5T Bag
Fits the One for Strings 5 and One for Strings 5T model amplifiers.
$89.99
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.014956 / 1.512039]
