Acus One for Bass Acoustic Amplifier (wood) Acus One for Bass Acoustic Amplifier (wood) Acus The Acus One for Bass is an amplifier designed for guitar Bass, Cello and Double Bass. Arts & Entertainment > Hobbies & Creative Arts > Musical Instrument & Orchestra Accessories > Musical Instrument Amplifiers Acus-One-for-Bass-acoustic-amplifier-wood 03001008 1699.00 DjangoBooks.com
Home / Amplification / Amplifiers / ACUS Amplifiers / Acus One for Bass Acoustic Amplifier (wood)
Acus Sound Engineering developed the One for Strings range to amplify the sound level of all acoustic instruments. One for Strings amps are designed in minimalist style, with custom speakers, cabinets and highly reliable electronic components, all together capable of amplifying harmonics with natural tone.
The Acus One for Bass is an amplifier designed for guitar Bass, Cello and Double Bass. Its extremely compact dimensions, reduced weight, and 400 Watt power make the One for Bass an extremely versatile amplifier.
One ForBass has 3 Channels, each with an input balanced XLR (with input High or Low selectable with special switch), unbalanced input Jack, reversal Phase, Gain, 4-band EQ, Effect Send for the internal effect. Each channel also features of separate Volume and BSS Filter (High-Pass) to have the maximum control on sound. Channels 2 and 3 are also equipped with FX Loop for external effects and compressed, particularly useful when combined with electric bass.
The One ForBass is equipped with headphone output with independent volume, anti feedback filter, Return Effect (for internal effects), Master Volume, 8 effects integrated, Phantom Power, Balanced Direct Output (Pre / Post Eq, Line or Mic level) and Tuner output.
03001007 - Acus One for Bass Acoustic Amplifier (wood)
$1,699.00 | Out Of Stock | Stock Notification
Specs
Frequency Response: 30Hz - 20kHz
Max Power Out: 350 W
System format: 1-way
Sensitivity 1W 1m: 95 dB
Crossover: Passive
Woofer: 10" High Excursion
Tweeter: Compression tweeter
Cabinet: Low frequency
Construction: Poplar Plywood
Weight: 28.6 lbs
Height: 46 cm
Width: 38 cm
Depth: 31 cm
Acus One for Bass Acoustic Amplifier (black)
$1,699.00
Out Of Stock
Acus One for Bass Bag
Fits the Acus One for Bass model amplifiers.
$139.99
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013311 Seconds Memory Usage: 1.415756 Megabytes
