Home / Amplification / Pickups / Schertler Pickups and Preamps / Stat Pickups / Schertler STAT-MACC-Set Electrostatic Transducer for Maccaferri-Selmer guitars (with Stat-Pre)
WARNING: YOUR BRIDGE MUST HAVE AT LEAST 5/64" (2mm) CLEARANCE FROM THE TOP FOR THIS PICKUP TO FIT. IF YOUR BRIDGE HAS MORE THAN 13/64" (5.2mm)CLEARANCE THEN THIS PICKUP WILL NOT FIT.
Stat-Macc is an acoustic transducer especially designed for application on Maccaferri-Selmer guitars. The concept-design is based on the Lydia technology, Schertler best acoustic transducer for guitar.
The Stat-Macc is engineered with an high quality electrostatic microphone inside the transducer, all construction materials (cork and cotton fiber) are selected for reach the more natural sound with the purpose of reproducing the sound of the Maccaferri-Selmer guitar with an high fidelity.
The transducer is fixed between the soundboard and the bridge, only the mechanical vibrations on the instrument are captured by the Stat-Macc. The transducer is completely isolated from all other acoustic sources, with the benefit of been high resistant to the feedback.
Stat-Macc is easy to install, anytime it can be applied and removed fast without the danger of damaging any parts of the guitar. Stat-Macc is supplied with an high quality class-A preamp.
Item: 6562
$609.14 $458.00 | Out of Stock | Stock Notification
Amp Specs
Schertler STAT-PRE Electrostatic Preamp
The Schertler STAT-PRE preamplifier is the perfect choice for use with the Schertler series of electrostatic transducers for classic string instruments. Versatile and easy to use, STAT-PRE provides volume control in a compact package. An innovative sub-bass filter protects the house system, or your on-stage amplifier, from distortion or potentially harmful signals caused by low-frequency spikes. Class-A constant-current design ensures faithful sound reproduction while providing up to 500 hours of playing time from a single 9-volt battery. Manufactured with a cast aluminum housing, the STAT-PRE can be floor-mounted or worn by the player with the optional belt clip. Stat-Pre Specs Stat-Pre Manual
$238.00
Schertler Yellow Single
$705.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.027477 / 2.836662]
