Schertler STAT-C Electrostatic Transducer for Cello (Pickup Only) Schertler STAT-C Electrostatic Transducer for Cello (Pickup Only) Schertler The Schertler STAT-C Set cello pickup provides superior acoustic amplification at high volumes. Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories > Cello Accessories stat-c STAT-C 357.00 DjangoBooks.com
Home / Amplification / Pickups / Schertler Pickups and Preamps / Stat Pickups / Schertler STAT-C Electrostatic Transducer for Cello (Pickup Only)
WARNING: THIS PICKUP REQUIRES EITHER A SCHERTLER PREAMP (STAT PRE OR PRE AIII) OR A SCHERTLER AMPLIFIER TO OPERATE (UNICO OR DAVID). CONVENTIONAL THIRD PARTY PREAMPS WILL NOT FUNCTION WITH THIS PICKUP.
Application
  • Ideal for rock, fusion and jazz players where high amplifier levels must not present a handicap
Features
  • High feedback resistance
  • Impressive “bridge sound”
  • NO piezo harshness or distortion
The patented Schertler STAT-C electrostatic bridge pickup stands out for its high feedback resistance and for delivering an impressive bridge tone without the harshness or distortion of piezo pickups. STAT-C delivers wonderful, rich lows and smooth, clear trebles, and works perfectly with signal processors and effects thanks to its strong, solid signal.
The STAT-C is the choice for the cellist in a modern and loud musical environment.
Amplification may be managed by any amp or with a full-range amplifier system such as for example the Schertler PUB 280 and 380 active loudspeakers with bass extension.
$452.00 $357.00 (Save 21%)
Amp Specs
Schertler STAT-PRE Electrostatic Preamp
The Schertler STAT-PRE preamplifier is the perfect choice for use with the Schertler series of electrostatic transducers for classic string instruments. Versatile and easy to use, STAT-PRE provides volume control in a compact package. An innovative sub-bass filter protects the house system, or your on-stage amplifier, from distortion or potentially harmful signals caused by low-frequency spikes. Class-A constant-current design ensures faithful sound reproduction while providing up to 500 hours of playing time from a single 9-volt battery. Manufactured with a cast aluminum housing, the STAT-PRE can be floor-mounted or worn by the player with the optional belt clip. Stat-Pre Specs Stat-Pre Manual
$238.00
Schertler Yellow Single
$592.00
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013511 Seconds Memory Usage: 1.407333 Megabytes
