Home / No Show / Henriksen JazzAmp Head 2CH
The new JazzAmp Head features two completely independent pre-amps, each with the same features as our popular combo amplifiers. This allows for two instruments to be plugged in at the same time with independent EQ for each instrument, or you can use with both pickups on a hybrid guitar and adjust the EQ to each pickup. You can also run a split signal to the amp, keeping one channel clean and one running through an effect chain or processor, allowing you to EQ the end of your effect chain separately from your clean signal. Each channel's line out is also independent, which allows you to run each channel separately to a board or recording device. You can also run pre-recorded tracks into one channel without that signal interfering with your instrument signal.
Item: 6905
$1,065.00 $799.00 | Out of Stock | Stock Notification
Specs
Size: 11" X 9" X 3", 7 lbs.
Controls: Volume, 5-band graphic equalizer, reverb with on/off switch and wet/dry mix control per channel.
Power: Maximum power is 160 watts at 4 ohms.
Warranty: Full 2 year warranty (see details on warranty page).
Line Out: Each channel has independent line out.
Speaker outputs: Two parallel 1/4" speaker jacks.
230v/115v Selector Switch: Yes
Henriksen JazzAmp Head Gig Bag
Heavy duty padded gig bag for carrying your JazzAmpTM Head. Large pocket will hold pedals, cables and some smaller music books. Click on the image to the right for a larger view.
$79.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.014661 / 1.484436]
