Home / Henriksen JazzAmp 110-ER
The JazzAmpTM 110-ER delivers amazing jazz tone with an added high frequency dimension that "sparkles", and it works great for those who play flattop acoustic and nylon string guitars as well. The 3 kHz and 10 kHz controls not only allow you to adjust the volume of the tweeter, but also allow you to equalize it in the overall mix to create the perfect blend for your desired tone.
Item: 6905
$999.00 | Out of Stock | Stock Notification
Amp Specs
Size: 14" X 14" X 8", 25 lbs.
Controls: Volume, 5-band graphic equalizer, reverb with on/off switch and wet/dry mix control.
Power: Maximum power on the JazzAmpTM 10-Plus ER is 160 watts at 4 ohms (this requires an extension cabinet). As shipped with a single 8 ohm speaker it delivers 120 watts.
Speaker: Eminence® Beta-A 10 with tweeter.
Construction: 11-ply Finland Birch, steel chassis, Tolex covering with metal corners.
Warranty: Full 2 year warranty (see details on warranty page).
Line Out: Yes
Extension Speaker Jack: Yes (must be an 8 ohm speaker cabinet)
230v/115v Selector Switch: Yes
Henriksen JazzAmp 310 Gig Bag
Heavy duty padded gig bag for carrying your JazzAmpTM 310 around town. The front pocket is large enough for music books, pedals, cables and more.
$119.00
henriksen 110 er
Henriksen 110 ER is the best jazz amp i have ever used. It is small, yet powerful and extremely clear.
Submitted by kristijan funaric on 04/14/2012 04:52:28 PM.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.014408 / 1.331558]
