Hello All,
I wanted to see if any of you have experienced this issue and/or could provide any suggestions...
I currently play a Gitane Stephane Wrembel model guitar through a Schertler Unico amp. I've always had issues with playing it amplified. I've tried the Audio Technica (too much noise/feedback), the K&K piezo under the bridge (less noise/feedback, but I don't care for the piezo sound), and now I just purchased the Krivo DjangoBucker (which sounds like a humbucker).
It seems the main problem is the sympathetic ringing I get (it's even a little too much acoustically with this guitar). I LOVE the sound of a Gypsy Jazz guitar acoustically and would like to go back to the AT Mic (as I think it would be the most authentic representation), but need to find a way to dampen the ringing. Obviously, right-hand muting isn't an option with this picking style, and I can only do so much with my left.
I do have a couple of thin, plastic shims under my bridge and wonder what would happen if I replaced those with something a little more "absorbing" (cloth, leather?).
I also wonder if strategically placing some dampening material inside of the body would work.
Any thoughts greatly appreciated!
Thank you so much!
To save time check the related Discussions…
Bottom right side of this page just above who online.
Some questions have already been answered and solutions are probably there.
you can also SEARCH FORUMS…
just above New Discussion box
good luck and
pick on
pickitjohn` :peace:
My experience is the more resonant guitars work better with mics because they are pushing more sound than the drier guitars. To some extent you can control the resonance and ringing with your playing as well as the picks and strings you use.
Not much help for your issue, but an interesting side note.
Try a Schertler amp and pickup if you know anyone who has one.
Gitanes tend to have a lot of wetness. Might be time to upgrade...
I've found piezo p'ups can often have that tinny, quacky sound if the impedance isn't matched to the amp's input. Piezo's have a pretty high (10 Mohm) output. If plugging straight in to a mic channel or standard guitar amp the input impedance is much less. Try a DI or pre-amp to match impedance. I use the K&K pure preamp.
